Map 4 E30 logs, please check
pilotbdub
Miami
Hello, I am currently with the following mods: BMS Intake, HKS plugs gapped to 0.022, 4.7 gal of E85 in full tank of 93, JB4 indicate E29.
0-80 run
How do my logs look? @Terry@BMS
this is my 1st log, is there anyone that can check it?
Those look pretty good, no big timing corrections. I would say do a bit more of WOT run 3rd gear all the way through 4th into 5th.
awesome!! thank you, I will do some more runs in both Map 3 & 4, just was not sure how it was running do to no flex fuel sensor kit. I did the standard 4.8 gal of E85 to a full tank of 93.
I think you’re pretty close to the sweet spot on your mix.:thumbup:
Late to the party but looks fine, no timing corrections, fuel pressure is holding up.
