Primary down pipes and high flow cats
Brianlynn0803
I just installed ultimate performance downpipe mid pipe with boiler S exhaust I have a K&N cold air intake hks plugs and bovs as well as a jb4.
Codes I’m getting
Po420 in the main one
But a p2096 was showing but is not anymore I only get about 100 miles at the most before the check engine light comes on with the code I have tried every map combo in sport mode I do have a Wagner intercooler that I’m bout to install I just ordered EWG wires and all new oxygen sensors and the fuel wires any other suggestions would be very helpful please this car is driving me crazy
Codes I’m getting
I think once you get the EWG and Fuel Wires set up send some logs to Terry and he will help you fine tune.
p2096 is a fuel mix code. So you have a vacuum leak, o2 sensor issue, or are running too much E85.
Also possible you attached a fuel wire wrong.
Get an 02 sensor defouler. It's a mini cat that goes over your O2 sensor. Or get a tune that turns it off. A piggyback can't do that. Or just get some black tape and your light is gone
So here is a pull from the other night could the afr be causing these codes p2096p2196po420
