Tramamission fluid longevity is highly dependent on max temperature of the fluid. On a GT-R, 6 speed dual clutch transmission with synthetic fluid, if you exceeded 172F, it required an immediate fluid replacement. In Canada, taxes in and out the door, $1800!!! (10 litres of fluid @ $125/litre)
People who tracked their GT-Rs on a road course, shifting manually (usually not the most efficient way to shift), would regularly exceed 172 degrees F in one track day. People who tracked their cars usually added aftermarket transmission coolers to keep the temps down. If you don't track your car, temps won't get near that, and normally advertised longevity can be expected.
