Reactive lucky cat boost gauge thing
SIMONGUEY
hayward ca
So! I love this item. I really want this item on my car! I have no idea how to install this item but they said I can def add it to any boosted car. Anyone have a know any step by step guides on what to do? Or how to install?
Instructions for any boost gauge are kinda' sparse on the forum but can be found.
You need to know where to T into the vacuum/boost line.
You need to have a 'add a tap' fuse to piggy back off a fuse that is powered with key on.
From a far more knowledgeable forum member (i forgot who posted it so i can give proper credit.):
(Screwdriver points to vacuum line to tee off for gauge)
Boost Gauge Install​
  • The ground was a pain in the ass to find a good one so I used a stud with a nut coming through the fire wall and I tapped off the 20amp power outlet fuse in the right side of the fuse panel for 12v.
  • The boost tube was the WORST I had to run it there the rubber grommet that the wires run to the ecu, I did use a fuse adapter and a O shaped terminal for the ground and the stud, and I think it was 3 or 4ft of line for the hose can’t remember and yup I used a T adapter.
  • to tap to the boost line which I believe I posted the right line to tap off of.
Certainly. I use this one and it's great because it only has power when the car is RUNNING. Wired with 2 5A fuses. The empty slot.
(i hope this helped)
For that device he want's, you need to tap into the sensor, not mechanical. For what it's worth, that is a $2.99 IC2 screen 1.3" square with a few images loaded on a $12.00 micro controller. I would not spend that money to look at a cat.
Very much appreciate the help! I will have my friend who would understand this better read this and help me out!
yeah, I imagined it would be cheap as hell lol. just something weird I would like to add. but tapping into the sensor would be easier for me . thank you
