Next logical upgrade to increase power?
drob39
Im running a jm4 tuner in map 2 mode. I have a after market intake, cat back exhaust, and down pipes and mid pipes coming in.
What should my next upgrade be if I'm looking to increase my 0-60 time? Lighter wheels? Intercooler?
Tcu: Transmission tune (Lozic, lap3 or tork). I’m running the same 0-60 times as people with map 2 Jb4 and I’m still on the stock ecu/no tune. 6398FAFB-78B1-4B48-A2FD-EF8513646B73.webp
Try a Jb4 they are pretty solid. never heard of a jm4, must be a knock-off?
Ha, JK, JK. seriously though, I also like the TCU idea. Intercooler is a good option, and then meth or CPI. Burger has good options for all of those.
Will the TCU and JB4 play nice together, you think?
I just got the borla type-s exhaust on, I like it. I see you have the same.
Can you run jb4 and lap3 together?
Yes, there’s someone on the Facebook page that has jb4 map 2 and the tork tcu tune hitting 3.7/3.8 0-60 times. It helps if you are awd, the tcu tune with rwd will be good too but you’ll need to practice more with the launches.
yes, it should all work nicely together. Borla is sweet! I do have bolt on tips though as the noise was a bit extreme with the stock tip set-up. Now it's perfect. Loud, but the noise is out back, just cruising it's just a bit louder than stock. From outside the car it sounds amazing, especially at WOT. make sure you have someone do a drive by for you!
Lighter wheels, wider tires,and front and rear sway bars, literally made my car "feel" faster..
What tips are you using now? I had the same thought about it being a tad loud.
Yeah I was thinking of going with lighter wheels but can't decide which ones.
Good vendors on here.. helped with proper offset,sizing etc etc
Check out the exhaust tip thread. Got mine from Aliexpress. Maybe $175. For
Four tips including shipping. Fake carbon fiber look, oval shaped, no trimming needed on the bumper. Can’t remember the size but it’s talked about in the tip thread in here.
I got those same tips on eBay and they were at my door in a few days
Whoa, that seems expensive. I pad less than that for all four including the $60 or so in shipping. Also are you sure that’s the right size for the Borla? I recently posted the exact alixpress items, I think on the exhaust tip thread.
