Schroedes
- Mar 1, 2021
Had my jb4 in for a week now. Been playing around with different fuels etc and trying to fully understand these logs. Today I pulled my step 1 Densos out, that I installed about 6 weeks ago. I wanted to check the gap etc. Based on the plugs looks like the motor had been running rich. I'm guessing from before I installed the jb4. So I cleaned em up and tightened the gap to .022. as I've been a little suspicious about my timing over the last week. Did these runs today on map 1 and 2. I did map 3 yesterday before the plug pull.. the fuel in there is about half 94 and half 91. Temp about 60 degrees, nice and dry.. my question is , as far as the timing, the numbers I see, are they degrees being advanced or pulled, and what exactly is it that I wanna see?? 0s across the board or matching numbers through each cylinder?? I've seen logs on here that Terry says are good with huge amounts of timing, just similar in each cylinder.. then I've seen other logs where people say that's real bad timing etc and it needs to be zero.. I'm trying to determine if I can comfortably bump up to map 3 and 4 with some E85, and I'm also trying to determine if I should get rid of these step 1 Densos and try the HKS. I didn't think I would have timing variation on map 1 as well with the fuel I have so I'm a little confused as to why I am.. plugs?, fuel? Or is what I'm seeing fine?? Any experts out there to clarify this more for me? Thanks
