My first dyno test. Any advice?
CheldonAc
Gresham OR
Hey everyone! So I installed the RaceChip GTS Black in my Stinger GT and I'm loving it. This weekend I'm taking it in for my first dyno testing to see the difference in power and I was just wondering if you guys have any tips to prepare and get the best numbers. I'll be running a tank or 99 to 100 octane in race mode and have cold air intakes and a carbon hood with functional heat extractors to help with the cooling. I'll be doing the test runs in the morning so it'll be around 70°F. Do you recommend anything else?
Hey I'm curious how your dyno went. I've been wanting to dyno mine with map 7 too
My best run was 415hp to the wheels and 500ft lb. of torque! About 90Hp and 100 torque boost from stock so I was really happy. I think the intakes and hood helped a bit as well :) Do you have any extra modifications besides the chip?
Nice numbers but stock is 365hp (unless it's a 2022 then it's 368hp) so that's an increase of 50hp and 124 ft lbs of torque. I also have a RaceChip GTS so I've been curious on numbers.
I have HKS M45iL plugs but that's for now. I'm hoping to order Stillen intakes and MBRP catback by the end of this month. Thanks for the info btw
Oh those numbers are at the crank so at the wheels the stock horsepower is about 325
No problem!
