What to do next Performance wise.
RIGS GT2
I'm wondering what's next to do to increase performance in my car.
It's my daily driver and I don't track it but, I do the normal rolls over 70 in the highways and the typical stop and go street race every once and an while.
My car currently have. Oil Catch Can, K&N Typhoon CAI, JA scoops, GFB Deceptor Pro II BOV, JB4 with plugs, Wind booster and the Borla Exhaust. I was thinking of removing the cats but then I will not pass emissions so that's off the table unless someone tells me how to pass them without the cats; then I'm thinking of installing an intercooler.
The reason behind the intercooler is that I have seen that when the temps here in IL. gets over 90 degrees the car does not run as well when is 70's.
Other option is I was seeing the WMI but, don't know how it works; does it's always ON or you turn it on with a switch to get that extra injection going?
And I'm skeptical to damage the engine or something using the WMI.
With this said and as mu daily driver; What do you guys recommend?
Sorry for the long post.
Thanks.
RIGS.
Meth or CPI my friend.
Both will give you huge gains. No, they aren't 100% all the time. To enable meth, you change to Map7 which ups boost and activates the flow. The flow is set by min boost so you can set up with for say... 8psi. Cruise around all day and never activate it until you get on the gas. There are other variables also like pedal position, current torque, so meth doesn't just squirt out randomly, BMS does an excellent job at controlling it in a safe manner.
CPI is similar in the sense of an additional injector in the charge pipe but instead of methanol from a tank, it uses the LPFP and sprays additional "fuel" (higher concentrate of Ethanol).
I see you have fitted GFB pro 2.
Which fuse holder did you plug into.
Photo would be appreciated
Hey RIGS GT2,
It looks like you have a great foundation already but there is still plenty you can do.
If you are looking for power gains, I would highly suggest the Ultimate Performance Downpipe Combo Kit. (Click HERE)
This kit is smog legal here in California due to its High Flow Cat design & it puts out a tremendous amount of power.
Some other options that you could consider are suspension upgrades such as the Eibach Pro-Plus Kit (Click
Here).
Feel free to reach out if you have any questions, need suggestions, or if you would like a discount on your order!
Enjoy the new ride,
Daniel @ the K8 Stinger Store
