Wiper blades that work well with the Stinger?
Why change from OEM? You can find replacement blades (just the rubber part) on Korean ebay and they do a great job.
I tried once a Valeo aero (or something like that) but it was slightly taller than the OEM and could be seen from inside the car while resting. I didn't like that very much. OEMs stay tucked away in my driving position and that's what I'm sticking with.
not a bad idea at all!
I despise waste and would definitely consider being able to only replace the blade rubber. Can you provide a link so we know exactly what to look for?
I only changed the driver side and the code is: 98351 1R000
You can find it here as well: 983511R000 Genuine Kia Drive Windshield Wiper Blade Assembly
I got it from ebay but the listing is not active anymore.
It's super easy to change. The moment you see the new rubber you'll figure it out. It's one metal clip that needs to go into a little hole at the end of the blade.
I changed the driver side when I 1st got the car the OEM blade chattered
I replaced just the OEM rubber blade with one out of a 26" Michelin (one metal clip that needs to go into a little hole at the end of the blade)
