Team Tonka
 - Jun 13, 2019
Give the ECU some time, after a bit of learning the deviations will likely drop a bit. Feel free to send your CSV file to Lozic to review as well and ask them about the timing deviations and if there should be concerns. I'm at 1.5bar and run 93 as well, I'm going to have the remap done so boost standby is off - I don't like it. Trying to decide if I go to a 1.4bar map. TCU is ordered as well, I'm AWD and mostly auto-shift, so doing a pressure of 2 and -7%. Like others have said, turn the windbooster off.I got the Lozic trio installed and went out for a drive a couple of times about 90 mins each.
I was somewhat familiar with the TCU but now going from level 3 to 2. Shifts are still fast but now don't have that bite that 3 does which I am perfectly ok with.
The AWD module does seems to transfer more power to the front faster but it difficult for a newb like me to know for sure.
First impressions of the ECU are...well maybe I shot too high (1.5bar on 93). It's still early maybe requires more time to adapt but currently JB4 shows on average 4.5 and up to 6.8 timings. JB4 also says that boost is going as high as 26...
What I think is the boost standby feature is somewhat undesirable. Under any throttle more than 10% it sounds like the turbos are spooling and every shift I can hear the stock BOV. Sometimes it does not sound great like when the wastegates are stuck open. Not liking that at the moment but maybe it's something I can get used to.
The thing I can't get used to is the surging or fluctuations under light acceleration. The car becomes what I can describe as an uncomfortable, possibly malfunctioning theme park ride. I can barely keep from larger deviations of pedal input. I used a lower sensitivity on the windbooster and still had a similar effect. I watch the needle/number of the throttle on the JB4 app spaz like a meter on a pressurized line going out of control. Not sure what to make of this.
Sorry for the long post I'll keep at it. Any input is appreciated, thanks!
