Group Buy - ISG (Idle Stop and Go)/Auto Hold, Proximity Lock/Unlock, Heat/Cool setting memory module
That's me above, but.... I was inspired by a guy on here named Budzique but he ghosted! I tried reaching him through his in YouTube also and I haven't heard back. The above video will show how you can get the car into sport mode every startup. It is NOT a memory module! Amazon sells that for $12.99. The video on my channel before this one turns off ISG safely for $.16 cents.
That's me above, but.... I was inspired by a guy on here named Budzique but he ghosted! I tried reaching him through his in YouTube also and I haven't heard back. The above video will show how you can get the car into sport mode every startup. It is NOT a memory module! Amazon sells that for $12.99. The video on my channel before this one turns off ISG (Idle Stop and Go) safely for $.16 cents.
Yea, I tried contacting him also
so what if I want to change the drive mode to comfort, etc later? looks like this way will always send it back to sport, correct?
When you start the car, the countdown begins (programmable) it then simulates one (1) clockwise motion putting it in Sport. If you want, you can put it in any position after that. The only exception is if you shut the car off in Eco, I think it will stay in Eco, so it will go one C/W from that. Everything else defaults to Comfort on restarts.
Yeap, I bought from them through their website. They were responsive initially but once I started to ask them on how to install on a RHD, they became less responsive and did not provide any form of help on the installation. I took a risk and check with a local audio installer (since they are good at wirings and stuffs) to install on my car. After I found out it's not working as it should, I tried emailing them multiple times (about every alternate days) but no response till now, since 21 Oct.
In my emails, I provided my observations. 1) There are 2 LEDs that lit initially, one of it will goes off after approx. 50secs. 2) If I were to come around within that 50secs, the auto unlock will work. After the 50secs window, if I were to come around, it will lock the car up again instead of unlocking. I took a video and sent to them.
I was wondering whether the CAN wiring was incorrect since it's a RHD, the wires might not be the same as LHD (the location of the fuse box is on the right and the CAN connector is on the left side of the car). Or it has to do with a defective module or the power going to the module. Or even the length of the wiring, as the installer had to extend the wires from the left to the right to the fuse box)
An update to my issue with the proximity module. Managed to find a local workshop that had dealed with this same issue and they found the solution to it after many many trials and errors. Paid them a token amount to get it fix (actually just to swap the 12v tap to another location) and that's it. It worked as it should.
Has anyone installed proximity unlock in a RHD 2021 stinger?
Do they still sell the AVM/SVM module to control the cameras? I haven't been able to find it anywhere.
Do they still sell the AVM/SVM (Surround View Monitor) module to control the cameras? I haven't been able to find it anywhere.
You have to specifically ask a place like shark racing to import it for you, you won't find it listed for sale anywhere in the USA.
I was on their site but I didn't see it listed there anymore. They only had the ISG and the drive mode module. Do I email them directly and just ask?
I was on their site but I didn't see it listed there anymore. They only had the ISG (Idle Stop and Go) and the drive mode module. Do I email them directly and just ask?
The item has never been on their website, you have to email or call them and ask about it.
"To enable or disable the module press 4 times on trunk button when the engine is off."
The trunk button is the one for the remote, not the one on your dash. I only pressed mine three times, the lights on my mirror flashed.
Hi,
I bought the "2018+ Stinger Combo Memory Module - Drive Mode, ISG, Autohold" from Sharkracing.
Unfortunately they only send a printed page which is hardly readable and didn't react on email.
With with the information from this thread I will be able to install it.
But does anyone knows for what the 6 DIP switches are used for?
I bought this and couldn't be happier the button still functions as on or off and it remembers your last choice, I Googled a coupon and got it for $99 free shipping, 100% Plug and Play 5-minute installation
Hello guys, I recently purchased the smart proximity lock / unlock module from shark racing. Unfortunately it didn’t come with any instructions. I‘ve e-mailed Sharkracing but as of now I haven’t gotten a reply.
Would anyone of you be so kind to share the wiring diagram / instructions with me!
Thank y‘all so much in advance!
EDIT: been to quick. Read through the thread carefully and think i found what i needed.
