7Andrei7
Hi everyone!
My car (2.0T GTL RWD) came with 19" staggered Continental ContriSport 5 tires. After 2 summers, my rear tires were almost completely done while the fronts still had about 5mm left (of 8mm). So I decided to only buy a rear set and keep the fronts for one more summer.
Since I was pretty unhappy with the noise and inability to properly balance the Continentals I decided to buy a set of Nokian Powerproofs for the rear. They have very similar style thread and I got the exact same specs: 255 35 R19 96Y XL.
Driving on the highway feels no different (except the lower tire noise coming from the hatch) but driving on side roads is very different. The steering feels more nervous and bumps in the road or a gust of wind launches the car sideways. I feel like I need to fight with the steering more while at the same time having less feel when I push it hard. It's very weird as it feels to both understeer and oversteer at the same time.
How can this happen? I've checked the alignment and balance when I installed them and all is perfect. There is no vibration. Just steering feels lighter and disconnected.
Could it be because the rear tires have much more grip? Or because they are softer or worse? The "handling" reviews are pretty similar for the Contis and the Nokians. However, Nokians are better at pretty much everything else. I never could have imagined that the rears would influence the handling so much.
I'm trying to figure out if I need to also replace the fronts or if the rears are really bad and I need a completely new set.
Thank you!!
Thank you!!
