It's not a tire issue my friend, it's an ECU/TCU issue. Do a search here, it's been discussed on several threads.I have a 2022 GtLine. With stock tires and wheels my car stops at 133mph and goes no faster. What setup will get me too 170mph.
ps my girlfriend has a 2019 AlfaRomeo Guilia and i keep losing races to her. Help me please
How about GT with A/S? The 140mph Merlin mentioned above?Top speeds are 130 mph for the GT-Line and 167 mph for the GT1 and GT2.
GT1 or GT2 with A/S anything is going to be limited to 140 MPH. Now, if you pick up a Stinger with A/S, and it's a previous owner acquisition, the only way to be sure is to know in detail the car's history, or do a test run.How about GT with A/S? The 140mph Merlin mentioned above?
Good info! Not that I'll have any use for exceeding 140mph (GT1 or GT2 with A/S anything is going to be limited to 140 MPH. Now, if you pick up a Stinger with A/S, and it's a previous owner acquisition, the only way to be sure is to know in detail the car's history, or do a test run.If you find yourself EASILY passing through 140 MPH into the 150s range, and still accelerating c. one MPH per second, then you better back off: because that car had Michelin PS4 tires as OEM; and pushing A/S up to 167 MPH could get you tire failure, especially if your A/S are "V" rated and not "W" rated.
You have to "crack" the ECU, and I have only read of it happening, not anyone on the forum (that I recall). Doing so would void your warranty; I don't think you could hide the hack from Kia. If you found a way, there are many mod-mad Stinger owners who would jump on that.Good info! Not that I'll have any use for exceeding 140mph () but how would one update their ECU if their Stinger is now wearing higher rated rubber?
GT-Lines that come with staggered wheels have a top speed of 150 mph for the 255 hp engine, but I don't think they do come with them in the US.Top speeds are 130 mph for the GT-Line and 167 mph for the GT1 and GT2.
I think Tork did a Limiter delete, but I'm not sure. Best bet is getting an extra ECU that's adjusted and to be honest if you're going to go this far you might as well tune it. Still not sure where you're going that you can reach those speeds in a 'safe' manner though. Just be sure whatever you do you have tires that are rated for above whatever you're trying to do.You have to "crack" the ECU, and I have only read of it happening, not anyone on the forum (that I recall). Doing so would void your warranty; I don't think you could hide the hack from Kia. If you found a way, there are many mod-mad Stinger owners who would jump on that.![]()
"In Mexico", of course, where else?I think Tork did a Limiter delete, but I'm not sure. Best bet is getting an extra ECU that's adjusted and to be honest if you're going to go this far you might as well tune it. Still not sure where you're going that you can reach those speeds in a 'safe' manner though. Just be sure whatever you do you have tires that are rated for above whatever you're trying to do.
I could be wrong (usually am) but isn't there also a factory limit depending on the drivetrain of the Stinger?Top speeds are 130 mph for the GT-Line and 167 mph for the GT1 and GT2.
I don't think this is real lmfaoI have a 2022 GtLine. With stock tires and wheels my car stops at 133mph and goes no faster. What setup will get me too 170mph.
you mean awd vs rwd? no, if you got an awd gt with summer tires you still get the 167 mph limit but most of them now have the 19" staggered a/s with 149 limit.I could be wrong (usually am) but isn't there also a factory limit depending on the drivetrain of the Stinger?
lmfao that is such a dumb decision by Kiayou mean awd vs rwd? no, if you got an awd gt with summer tires you still get the 167 mph limit but most of them now have the 19" staggered a/s with 149 limit.
Especially considering the primacy tour a/s tires that come on it is rated for 168mph...lmfao that is such a dumb decision by Kia
just keep it 167 for all the V6 models in my opinion
I have the potenzas but once I hit 135 it goes limp I’m guessing the ecu or the tcu has part of this plus I have a 2019 that’s AWD 3.3That is a funny question. You did not do your research on speed limiters by trim. Mostly it IS a tire limit: or rather, the OEM tire determines how Kia set the ECU/TCU: I say this because the 3.3L twin turbo has two limited speeds: the advertised one of 167 MPH, and the not discussed (in polite society) one of c. 140 MPH: and the difference is caused by the tires that are OEM: the Michelin PS4 are speed rated "Y" (or even (Y)) at 186(+) MPH; the A/S, whether Michelin, Continental or Bridgestone/Potenza, are speed rated at "W", which is 168 MPH; or even "V", which is 149 MPH; and to stay well within the safety spec the speed limiter is kept at c. 140 MPH (I believe that earlier MY18 Stingers had a speed limiter for A/S tires set at 130 MPH, because, iirc, the Bridgestone/Potenza used at the time was a "V" speed rated tire).
Is there a staggered wheel option for the 2022 GT-Line? If there is, it will probably come with Michelin UHP tires and have a higher speed limiter than yours - which is apparently 130 MPH: all actual top speeds are a few MPH over and above the speed limiter setting: e.g., I've read on here of A/S equipped 3.3L pushing close to 150 MPH; and at least one member has pushed his 3.3L to 171 MPH.
And, welcome to the forum.![]()
