Eibach sways and new end links?
Ric 'Ochet
Dumb question.
Do I need to replace the end links with the Eibach sways? Is it necessary? What’s the benefits? The car won’t be tracked, just wanted it tighter on the twisties. FYI also lowering vehicle w/Ark Springs if that matters. TIA
Nope! - you can use the stock end links... not sure if the springs change my answer
I didn’t think so but I tend to overthink
I think someone here even commented (or their mechanic did) that the stock end links are pretty beefy.
I have front and rear eibach sways with Ark springs, and stock end links. AOK! car handles great!
I have Eibach Swaybars & Whiteline Heavy Duty Endlinks since 2018 still with OE springs with adjustable ride control, a great all round package upgrade, nice & firm set up providing greatly improved handling & stability without compromising ride quality.
IMO OE Endlinks are a little underdone, especially the fronts which are 300mm (12”) long & the main rod between to two ball joints is too thin.
Good to know..they go on tomorrow and just wanted to make sure
