DekCan
- May 4, 2020
- Location
- This will allow people to see y
When it hits boost is it just flat with no power? I installed my bms intercooler and the unit is great but install was a pia. The driver side oem piping is stupid. Chances are high you have a leakJust installed new BMS intercooler with gapped plugs but lost a lot of HP, struggles to get to 60mph. Car doesn't feel like it's getting air at all.
That's correct. It's just flat with no power when it suppose to hit the boost.When it hits boost is it just flat with no power? I installed my bms intercooler and the unit is great but install was a pia. The driver side oem piping is stupid. Chances are high you have a leak
I had my drive side pipe blow off and did what your describing. I heard it come off so I knew. You can jack the car up and take off the drive side of the undercarriage and check.That's correct. It's just flat with no power when it suppose to hit the boost.
Defiantly will, do you think it can be the plugs?I had my drive side pipe blow off and did what your describing. I heard it come off so I knew. You can jack the car up and take off the drive side of the undercarriage and check.
With no boost I highly doubt it. If it were plugs you would get misfires or stumbing not 0 boostDefiantly will, do you think it can be the plugs?
Yeah it's plugged in. When we installed the intercooler we made sure everything was secure. Might have to double check.Yeah sounds like you have a leak. One other super simple thing to check is your boost pressure sensor. Not sure if you would have unplugged that or not, but I accidentally left mine unplugged once and had no power at all. It’s right here if you didn’t know. On your passenger side.
