I have a 2020 Kia Stinger GT1, so a couple of months ago I replaced my rotors with some new R1 eLine drilled and slotted rotors and new R1 pads. Right after it my car vibrated like crazy when braking. Had my tires balanced and wheels aligned as I was told this was the cause. The braking vibration stopped but the car still vibrated at highway speeds (80-85 mph). Was told the tires were too worn out and that they too needed replacement and that the recent balance and alignment showed this. Put new tires on the car and still the same vibration issue. Was told that the new rotors were warped and this was causing the vibration even if no more braking vibration was present. Reinstalled the OEM rotors and nothing fixed. Had KIA replaced my OEM rotors for some new ones and nothing. Finally was told by Kia that the car needed Road Force balancing and this should fix the vibration on highways. Did it and nothing. The tire shop replaced the recent new tires for a whole new set, did the Road Force again and an alignment and still the freaking vibration does not go away. I am desperate, any ideas what this might be. Kia say it is nothing on the car, but dang. New tires, new rotors, Road force balance, alignment and still after I pass the 80mph’s it vibrates like crazy. Will appreciate any suggestions.
