Read this thread.What about the LAP3 tune, it has been tested in the US by them and seems to work fine.
Cool! I already have a JB4The jb4 is a really awesome tuning option. It integrates into the CANbus through the obd2 and allows data logging. Then the tuning part has predefined maps specifically for the stinger. It is essentially a cobb tuner without directly flashing the ecu. I like the jb4 more than cobb.
I didn't go through the whole thing, but I believe he has the Lap3 piggyback not the tune.Read this thread.
3.3TT - Stinger Misfire
I should have specified the other stinger running meth had the 1.7 bar tune. Looks like you are the only other stinger at the moment with 1.5 bar. Lozic did say he could do some adjustments to run E10-E30. I have not sent it back for a refresh to try. I am assuming with meth you have not had any issues of it getting worse between 1/2 and 1/4 tank of gas and lower.anyone have any updates from lozic or had any adjustments made yet? On the 1.5 bar I run 93+ 100 %meth and see a constant 2.3 pull across the board, never any less and usually more. Thinking about dropping to the 1.3 bar tune with a few adjustments to smooth out the power delivery and using the JB4 for additional "track day" power increments.
Agree.From what I understand there are a few Stingers running 1.5bar and a few G70s as well. In terms of the 2.3 degrees of timing, I've seen this with the 1.3bar as well. Lozic didn't think it was accurate in terms of knock based ignition retard. I'm not sure what it is but it seems more like some sort of programmed response from the ECU possibly. It would be good to compare notes on this as it's got me really curious.
Learning a lot from this thread. It doesn't appear this ECU has any adaptations apart from short-term timing in order to prevent knock? If that's the case, I'm surprised there are so many eager to change hardware on this platform at all.
Also really surprised to see G90 ECUs installed into Stingers when someone in the aftermarket industry says there are differences in firmware between the two.
FWIW I've got a G70 on the way. Just shopping for options.
