Had to replace the plugs again for the 3rd time in 14k miles since using JB4. Seems like every 4-5k it starts to misfire, I change the plugs and its good to go. Is this normal?
The CEL only came on the first time because I wasn't sure what the problem was and got a misfire code. As soon as the car starts to "stutter" when I accelerate I change them, so I not sure if its the same cylinder each time.
Its the wrong plug to use i ran the same and the tips would melt went to have it dyno done to see what was going on when they knew i was running that plug they said they never run a iridium plug on a car with boost the plug to use is brisk er155xc now have more power and dose not melt the tip
Yea, first set at .022 and the last two sets at .020. The .020 gaps lasted a little longer than the .022
I'm using Denso with .24 gap. JB4 (map 2), 93 octane (top tier only), intakes, and secondary pipes. No issues up to now...just crossed over 15k on the odo.
My Denso IKH24 .022 plugs lasted about 11.5k before getting misfires at >50% throttle. Just replaced them today with IKH27 with 0.022 gap. Hopefully these last longer because replacing them isn't fun.
Hey terry is the stock hks gap ok for 3.3 with Jb4 on map2? Thought they would have came pregapped from my supplier but they weren’t so I found out after having them installed. And trying to figure out next steps.
They aren’t gapped. So I’m on map 1 so far with no issues but earliest I can get them changed is Tuesday. Hopefully I’ll be good for map 2 then. It’s a whole headache.
