3.3TT First time MAP Review
darren.blomquist
@Terry@BMS New logs from first time user. Primarily concerned with MAP2 log (3rd-4th pull). Tried MAP3 with 4gallons of E85 from a launch but if I'm reading it right its pulling timing. Might get the flex fuel kit to verify mixture before further logs. Let me know your thoughts.
Mods:
BMS Intakes (450hp Kit)
EWG Wires
Denso's gapped at .022
Thanks,
D
Timing corrections are not happy. Stay on map2, disconnect the battery ground 5 min, and grab another map2 log for me to see if a reset helps.
@Terry@BMS Sorry for the delay. Here is a Map2 pull 2nd-3rd and later in the map is a launch through 3rd. Looks like the reset helped a lot so I did Map3 2-3rd as well (not a great pull log wise sorry).
Thoughts?
Short runs but timing looks good better now on both maps...
Map3 is probably as high as you want to run it I think.
Terry I have had the same issue a couple weeks ago and the battery disconnect helped clear the corrections. I installed your wmi kit yesterday and the same thing I had corrections a lot and then did a battery disconnect and they cleared up. Why does it keep happening to me?
Just checked a log from this weekend and mines doing the same thing again. Wth
