CoconutRob
- Jul 9, 2017
I have 6750I'm assuming most are sticking to this for RPM's?
Rev limit Drive rpm 6000 rpm
6000
tork tune raised it also and no one has blown anything yetWhat is the recommended Rev limit for best HP/Torque with their tune - isn't 6750 rpm overshooting that?
Part of the TCU tune is the option to shift earlier than redline(6750) during wide open throttle. It is prepopulated at -5%, which should equate to just a touch over 6400RPMsWhat is the recommended Rev limit for best HP/Torque with their tune - isn't 6750 rpm overshooting that?
No. You want to shift earlier to #1, not run outside the peak power, and #2, to be in the best part of the powerband after the shift.tork tune raised it also and no one has blown anything yet
from what i know it just keeps on pulling and doesn't run outNo. You want to shift earlier to #1, not run outside the peak power, and #2, to be in the best part of the powerband after the shift.
Here's the thing:How is no one blowing up their engines/trannies with this? Such a huge delta in torque on stock internals freaks me out a little bit.
Not sure I have the willpower to not install all three pieces at once, hahaha!It would be interesting to see your time with just the ECU vs the ECU, TCU and AWD.
	Same hereIt would be interesting to see your time with just the ECU vs the ECU, TCU and AWD.
New to the party but saw this......
