As the title says, Which sway bar set should I go with? Are the Eibach that much better than Whiteline? Or ARK? With whiteline being almost 100$ less I'm really leaning that way unless they really aren't any upgrade.
I mean, its VERY easy to add this to any bracket definitely not a selling point. SorryEibach - it's the only one of the three with a zerk / grease fitting...
Did you do that the same time as lowering springs?I have Whiteline front and rear and theyre great. Car is so much more flat and stable when aggressively cornering. Feels like I have endless grip
I had my springs for about 5 months before I got the swaysDid you do that the same time as lowering springs?
Alright, and you still noticed a good difference. That's awesome.I had my springs for about 5 months before I got the sways
When you're talking about a 100 dollar difference between the two and you're getting a zerk fitting on all the brackets versus buying the fitting separately and drilling the holes and needing a tap and die set yes it's a selling point.I mean, its VERY easy to add this to any bracket definitely not a selling point. Sorry
Zerk fittings are a couple pennies each and you don't need a tap and die set for them, they self tap. So 100+ to drill 4 holes and a dollar for some zerks is not worth it to me. I went with the whiteline. They are on sale for 270 shipped for the set.When you're talking about a 100 dollar difference between the two and you're getting a zerk fitting on all the brackets versus buying the fitting separately and drilling the holes and needing a tap and die set yes it's a selling point.
I have the eibachs and they're amazing, cant recommend them enough.
May bad, didnt know they self tap.Zerk fittings are a couple pennies each and you don't need a tap and die set for them, they self tap. So 100+ to drill 4 holes and a dollar for some zerks is not worth it to me. I went with the whiteline. They are on sale for 270 shipped for the set.
I’m new to the modding screen. I’m interested in getting the sway bars but don’t want to lower my car (scraps the snow when it snows). I don’t need to get the lowering springs right?I'm personally a big fan of the Eibach Sway Bars.
They have been a long-time industry leader when it comes to making suspension components.
This is one of the mods that you will instantly feel the difference once it is installed.
If your Stinger has stock suspension right now, I would suggest going with the Eibach Pro-Plus Kit.
If you already have lowering springs installed or coils then I would suggest getting the front and the rear Eibach Anti-Roll Sway Bar Kit.
Feel free to reach out if you have any questions or if you would like a discount on your order.
Correct, you do not need to get lowering springs to add sway bars. They just add another level to the handling. Sways will definitely help without springs though.I’m new to the modding screen. I’m interested in getting the sway bars but don’t want to lower my car (scraps the snow when it snows). I don’t need to get the lowering springs right?
