3.3TT Log check please
ddft1949
Just got my jb4 installed and did a few WOT runs. Can someone check the logs to see if it's fine? Thanks!
3.3T
Mods:
Intake
New plugs gapped
Due to where I live, there isn't any 93 gas since 91 is the equivalent at this altitude.
Just noticed my ign 2 - 6 is pretty low compared to others.
You can change how timing is shown
FutureUseA (FUA) as of v22 firmware:
FUA 1: Show cyl 2-6 as raw timing rather than timing corrections.
Speaking of, the log looks ok. You've got some timing variations and that's expected with 91. That's why your button specifically says 93, and 91 is for Map1, the car will actually run better.
Thank you! When you say "run better" on map 1, do you mean more responsiveness, more power, etc than map 2 using 91 gas?
3.3T
Mods:
Intake
New plugs gapped
Some timing corrections but otherwise OK. Map2 is as much as I'd want to push it, and there is a chance you might be faster on map1 so compare the two.
