I own a 2020 Stiner with the 3.3 V6 I only have 2000 km on her and Yes I too hear this ticking noise on start up. I was going to speak with dealer and decided to google this , only to find that others experience the same issue.Do all Stingers have a very loud, What I believe is lifter noise, on cold starts? Mine does. It last 30 seconds to a minute and sound like a diesel truck. It's quiet on warm starts. Kind of embarrassing considering what I paid for the car. DOn't hear it in an Audi S5 Sportback. I understand the noise happens because kia uses solid lifters instead of the hydraulic lifters like most manufacturers? Anyone know have this same issue and can confirm the cause? I went to the dealer and they said it was normal. I had them cold start a new one siting on the lot and it sounded the same.
no issue, a normal high pressure fuel pump sound upon cold start. If you google high pressure fuel pump ticking , you will see that pretty much all direct injected car forums have the exact same question..I own a 2020 Stiner with the 3.3 V6 I only have 2000 km on her and Yes I too hear this ticking noise on start up. I was going to speak with dealer and decided to google this , only to find that others experience the same issue.
I'm hoping this isn't a serious down the road problem.
Ian Nicholson
Ontario Canada
I read somewhere in the manual that the valve noise on start up is from the variable valve timingDo all Stingers have a very loud, What I believe is lifter noise, on cold starts? Mine does. It last 30 seconds to a minute and sound like a diesel truck. It's quiet on warm starts. Kind of embarrassing considering what I paid for the car. DOn't hear it in an Audi S5 Sportback. I understand the noise happens because kia uses solid lifters instead of the hydraulic lifters like most manufacturers? Anyone know have this same issue and can confirm the cause? I went to the dealer and they said it was normal. I had them cold start a new one siting on the lot and it sounded the same.
I noticed the same noise , when I inquired into this I was told it is Not Lifters.Do all Stingers have a very loud, What I believe is lifter noise, on cold starts? Mine does. It last 30 seconds to a minute and sound like a diesel truck. It's quiet on warm starts. Kind of embarrassing considering what I paid for the car. DOn't hear it in an Audi S5 Sportback. I understand the noise happens because kia uses solid lifters instead of the hydraulic lifters like most manufacturers? Anyone know have this same issue and can confirm the cause? I went to the dealer and they said it was normal. I had them cold start a new one siting on the lot and it sounded the same.
I've had the same noise as everyone else. After 5 trips to dealer, Kia field tech diagnosed as issue with design of the fuel pump& housing.. however, other mechanics say it is the lifters. I believe its two problems.. fuel pump & possible lifters.. cant post link.. so Google "kia-stinger-lifter-tick-diagnosis".. 700r4transmissionhqI noticed the same noise , when I inquired into this I was told it is Not Lifters.
I was told it is the HIGH PRESSURE FUEL PUMP.
I hope this is correct, because if it is Lifters that would No doubt damage the cam and lifter
Your wasting your time! Normal means Normal. But hey knock yourself out.I've had the same noise as everyone else. After 5 trips to dealer, Kia field tech diagnosed as issue with design of the fuel pump& housing.. however, other mechanics say it is the lifters. I believe its two problems.. fuel pump & possible lifters.. cant post link.. so Google "kia-stinger-lifter-tick-diagnosis".. 700r4transmissionhq
I'm schedule to take it back in for this..
Thoughts?
Standing in front of vehicle. fuel pump noise is on the right (driver side) & the other noise is on the left (passenger side) and can be heard better after fuel pump noise lower... the more issues/info documented, the better for current & future owners..Your wasting your time! Normal means Normal. But hey knock yourself out.
Thanks... what is high test? I use Seafoam in my Charger.. what are your thoughts on Techron vs Seafoam?I’ve had stinger for 3 years now. Driver side is high pressure fuel pump noise also along with direct injection. Passenger side noise is also do to direct injection. Fuel injection with direct injection is very loud and will somewhat sound like lifter noise. I’ve noticed sometimes louder on passenger side . So I run a bottle of Techron through to clean and lube injectors and it Seems to settle injectors down. Always use high test and change oil with full synthetic. Kia only uses semi synthetic on there changing and turbos on these cars roast the oil quick.
