Group Buy - ISG (Idle Stop and Go)/Auto Hold, Proximity Lock/Unlock, Heat/Cool setting memory module
So I just installed the proximity lock but it does not seem to be working. Not sure if it is wired correctly. I have the top bcan tapped into the white wire on the mf11 and the bottom one wired to the brown below it. Is that correct? I have the 2 led lights on the module. What should the dip switches be on?
It's been a while so I can't remember. :) Make sure your wires are connected according to install doc from SR or see if this post helps. As I recall 2 leds lit sounds correct and you do not change the dip switch.
Part of the problem is that my taps weren't tight. Got it to lock, but won't unlock when I walk back lol
Is you welcome setting turned on? It should unlock when the mirrors fold out. Also make sure "double press" lock setting is disabled in center console as well.
Anyone have an issue with the auto start/stop not working after installing the proximity lock/unlock module from shark racing? I noticed mine does not kick on now after installing the module. I just get the yellow icon on the dash. Not that I mind really. Just curious
I have no issues with auto start/stop, but I have a ISG module installed. It works as it should. I would check wiring. If anything is draining your battery low enough, your ISG will not work either.
the more I read on this thread the less those module are attractive ...
I have no issues with auto start/stop, but I have a ISG (Idle Stop and Go) module installed. It works as it should. I would check wiring. If anything is draining your battery low enough, your ISG (Idle Stop and Go) will not work either.
I suppose the proximity module might be draining just enough for the isog to not work.... but even after driving awile where the battery should be charging, it still doesn't seem to work.
You might want to put a charger to it just to be sure. I've read driving around merely maintains the battery and doesn't charge enough.
modules are available in gmarket at half the price.
However, Here is my experience of installing Proximity Module and Heated and Cooled Seats Memory.
I used Posi-tap 2022m for installation
Proximity Smart Door Lock Module
1
2
Remove the cap from the blue cable
4
5
Remove the OBD port
6
Done.
Notes.:
2 led lights on the module means successfully connected.
Now make sure to enabled Welcom in cluster settings.
To enable or disable the module press 4 times on trunk button when the engine is off.
Heated and Cooled Seats Memory Module
1
Watch this video to remove the center console.
2
Done
Notes.:
Nice! You understand Korean! Maybe I should get one and test out whether it's really a faulty module (the one I got from Sharkracing) or the RHD wiring is different from LHD, hence not working as it should.
@bosaad Is there another connector or place I can tap into B-CAN L and B-CAN H for the proximity door module?
