Not an expert, but here is what I've read: some recommend the use of plastic intakes due to less heat soak. Small gains can be seen on the dyno regardless. Maybe the better flow is more significant than the higher temp? Many don't see much performance benefit over the stock system, but it looks and sounds cooler.yes, engine air (not cabin air). Thanks.
I hear (a) about how hot the V6 gets and how well the compartment retains said heat, and (b) about replacing the factory intakes with aftermarket units--that draw air from the hot engine compartment. It doesn't make sense.
Do you have drain holes in your air Box? Also how often do you have to clean the bugs out?I switched to using the bigger mouth snorkels with the factory air box and a drop in AEM filter. My best 0-60 mph with the car completely stock was 4.59 seconds. I got a 4.37 second 0-60 mph the other day without using Launch Control. I just simply mashed the gas from a dig and still got under 4.4 seconds.
The snorkels are for real. They just flat out work and they are not expensive if you get the bigger mouth ones.
I also got a 12.72 1/4 mile time with the snorkels and drop in filter. The best thing is that I had a 110.54 mph trap speed. That is 2.5 mph faster than my best stock speed. The online calculators say that is about 25 HP.
The stock air boxes can act like a ram air affect to the filter. That helps the panel filter flow the same air as a cone filter but still have the heat shielding that the stock box offers.
I don’t have drain holes in mine. However, I barely ever drive mine now and I almost never drive it in the rain.Do you have drain holes in your air Box? Also how often do you have to clean the bugs out?
