FMIC or not...
BHamm
Trying to decide if I should order a Johnny Tig FMIC. Not the cheapest upgrade. I have all winter to wait for it, along with my JT Intake. Also have BMS Meth kit to install before spring (BMS12), and plan to order MBRP Pro series exhaust yet too (and tips).
Performance Mods so far are only the JB4 (EWG not on yet), and lighter 18" rims if you count that.
Thoughts on the FMIC?
Just my 2 cents...
IC's don't make the car go faster, they keep them from going slower. If and only if it's HOT. I'm not sure where you are in Canada but if you don't have heat soak issues it might not be a necessary mod. With the mods you have now, you're a high 11 sec car, that's without the EWG cables. If you get a custom Map6 tune using the cables, and the appropriate fuel, you could be mid 11's.... All with the IC you have.
ps.. Brake snip is mandatory for those times.....
I just installed the BMS FMIC, had the AP intercooler, BMS much better
Thanks Darrin. I will do the Brake Snip in spring. Central Canada, not to hot in Summer. I have an opportunity to save a bit on the FMIC if I get it shipped with the intake when its ready.
Looks good Rob, and the BMS does cost less than the JT, about $500 less for me.
