moinmoin
1000 Posts Club!
This year brought us a new specification for motor oil; ILSAC GF-6 / API SP. One of the primary goals of the new oil spec is to reduce incidence of two problems gasoline direct injection (GDI) engines have been experiencing.
GDI blasts the fuel directly into the combustion chamber at high pressure. This leaves less time for the air and fuel to mix together. The resulting air/fuel mixture may burn unevenly which may generate a lot of soot. As the pistons move up and down, the soot gets mixed into the motor oil. The soot travels with the motor oil through the engine and causes wear.
CONTINUE HERE:
RockAuto October Newsletter | Early Edition
RockAuto ships auto parts and body parts from over 300 manufacturers to customers doors worldwide, all at warehouse prices. Easy to use parts catalog.
