davebo
Basically if you want more performance out of the Stinger just get the LAP3 tuners and always run Premium?
Those are RON ratings (Research Octane) vs. the R+M/2 (or the average of the Research and Motor Octane ratings) we use in the U. S. and Canada. Our R+M/2 (also known as AKI) numbers are lower than RON numbers for the same "octane" level of gas.in our region we don't have 87 nor 93 .. just 91, 95 and 98 oct.
i use 95.
Yep, I filled my last tank with 87 just to try it out. I noticed the difference in responsiveness and overall thrust. Not putting 87 anymore.
Just filled up my gt2 for the first time. I did 93 but WOW that is expensive. I think I will back down to 91 or maybe 87 but likely just stick to the midgrade.
I am surprised as to how small the gas tank is knowing the mpg is so low.
Fuel efficiency should improve as the engine breaks-in...Same, was thinking a 400-mile range would be more fitting. I've been getting ~320 miles/tank.
Interesting. I’ve only used 87 so far but switching to 93 next fill up. Curious if I’ll notice a difference.
Premium is recommended. But the manual says to run 87 or higher. Haven’t tried 87
I've been trying to find the page where it says this, but I can't find. Can you tell me what page this spec is on.. thx
FUEL REQUIREMENTS
Your new vehicle is designed to use only unleaded fuel having a pump octane number ((R+M)/2) of 87 (Research Octane Number 91) or higher. (Do not use methanol blend- ed fuels.)
The official documentation is very ambiguous. I believe it's only the website that says premium is recommended. The manual goes into technical detail on fuel quality and blend restrictions, but not octane requirements. The word 'premium' occurs once in the 560 page US manual, and it's related to a fuse.
That’s because premium is a marketing term that can mean different things.
The technical information they would use is the Octane number you quoted.
Looks like it recommends 91 or above which is normal for most higher performance turbo cars.
Very first page after the table of contents.
All modern cars will adjust timing to prevent engine damage as you switch from one octane to another.
The question that is important to get a confirmed answer is whether the power and torque ratings of the car are valid with 87 octane gas. If so, great and you will get a nice boost if you use higher octane. If the car is "recommended" to use premium/91 or higher octane just to achieve the advertised power numbers, then that is a different story. Most European turbos require premium to get the advertised numbers.
