TheBusch
- Sep 10, 2020
For those of you have who have added subwoofer(s) to their stock systems, I want to know what the best tap-off would be. Should I tap before the amplifier and not use the stock sub, or is there no issue with simply tapping off the stock sub and leaving it connected?
In addition, will I need an LOC from either of those options or are they pre-amp ready? If this answer changes based on trim level (GT, GT1, GT2) please specify. Thank you!
Also, if anyone has found a good spot for a decent sub box that does not take up room in the center trunk space, let me know. I assume smaller but capable subs would be the better option.
