Bear
A buddy convinced me to purchase an OBD2 sensor for the Stinger and an iPhone app to get readings.
I have to say it’s pretty interesting and fairly cheap. The app is $9 and the sensor was ~$22. You can access probably about 100 different readings while driving and can record your trips along with the information. You can get fuel rate, engine load, mpg, and plenty more. It allows you to build your own radial or digital gauges. You can modify every aspect of the gauges...down to how long, skinny and outline of the radial gauges.
Will be interested to see this information after an ecu tune or piggyback.
