westcoastGT
5000 Posts Club!
Game changer !! Well done !!Here we go!View attachment 25241
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Wow what an improvement. Looks great Dom.Here we go!View attachment 25241
Yes I'm very happy with the result. The two parts (exhaust tips and the diffuser) only cost €184. Money well spent!Wow what an improvement. Looks great Dom.
@Dom
I know there are 2 bolts under the exhaust tips but are there any on top, or any other type of fastener?
Thanks, I suspected same but couldn't get my hand up far enough to feel the top. So can the tips be removed without dropping the diffuser?Two above (to the inside of the diffuser), two below (from the underside)
$134 euro where do I purchase? Dom send me a PM I am a new diesel ownerYes I'm very happy with the result. The two parts (exhaust tips and the diffuser) only cost €184. Money well spent!
I ordered the two parts from my nearest Kia dealer (Kia Offers - Todds of Campsie | Kia Dealership Derry / Londonderry) but the price should be the same in any dealership.
Realize this is old but worth a shot haha. Got a new diffuser to swap on and wanted to check the size of the screws you used to replace the drilled out rivets. Try and make sure I don't need to make a trip to the store in the middle of it haha. Thanks!Ok Dom here you go. The job all in all was easy but not simple. You do have to drill out two rivets, one on each side. I circled one in photo 1 they are soft a drill out very quick. Then basically it's 4 bolts ( 10mm) that hold the diffuser to the bottom of the exhaust outlets 2 each side, circled in photo 3 and a number of push-pins like circled in photo 1, a proper tool helps with these. The exhaust outlets will come off with the diffuser, then are removed from the diffuser, two screws each. Now look at the cicles on photo 3, braces are attched to these with push-pins and are a bit tricky getting out and putting back. Once all the push-pins are out start pulling the diffuser. Start at one side by were the rivets were and pull firmly but with caution and the clips will start coming out. The diffuser is quite flexable so it's kinda like peeling it off from one side to the other. Phote 4 just shows what we replaced the rivets with, I will likely replace these with smaller stainless. Before you start hose the the hell out of the inside of the diffuser, a lot of dirt and gravel was built up in there that you don't want in your face as you're lying there on your back. Putting the new one on we started from the centre and worked out, in hindsight I think it might have been easier to work from one side to the other. We had a bitch of a time getting the last 4 or 5 clips on each side by the rivets. With the diffuser being so flexable I think working one side to the other might work better. I huge thank you to my "Stinger Winger" Westcoast. He once again provided the work space and the enthusiastic help that made the job a blast. Thank you so much Westcoast you're a beautiful person that I am so happy to have met. Good luck Dom. Cheers.
Sorry can’t remember. Don’t recall it being an issue.Realize this is old but worth a shot haha. Got a new diffuser to swap on and wanted to check the size of the screws you used to replace the drilled out rivets. Try and make sure I don't need to make a trip to the store in the middle of it haha. Thanks!
No worries, thanks for the guide! Will grab a few different ones to be safe.Sorry can’t remember. Don’t recall it being an issue.
I personally didn’t. Never had an issue.Realize this is old but worth a shot haha. Got a new diffuser to swap on and wanted to check the size of the screws you used to replace the drilled out rivets. Try and make sure I don't need to make a trip to the store in the middle of it haha. Thanks!
