I was going to go with the endlinks as well but am starting to think the same, so on the back burner for them. Sure drunken ordering is fun...:confused:..but probably best to avoid. :thumbup:
The guy that installed mine said the OE endlinks are perfectly fine..no need to swap them out. He works primarily on super cars and highly modified builds but he was verrrrry impressed with the Stinger. He said he'd buy one of these over any of the Germans and he works on those daily. That says somethin. Also said it was one of the best shades of red he's ever seen...I would agree :thumbup:
Thats May taken care of , bit sad for my old plates coming off. These should freshen things up a bit.20200529_170218.webp20200529_170218.webp
Very, Very nice Oz, you will have to post a pic when on the car
Thanks Flame appreciate it:). A couple of digs on FB so far. Something about a Samsung S7 :D:D:D:D
Thanks for that. Very nice to know:)
When I was parking my Stinger in the city's parking garage, saw a friend and fellow club member's Stinger parked there too. So of course, I just had to park next to his.IMG_20200530_190044.webpIMG_20200530_190032.webpIMG_20200530_190019.webp
Remind me to never move to a state that requires license plates on the front...
Yesteday i installed 4/6 sparksies and bms intake filters.
Today i installed the last 2 sparks and jb4, assuming i drive on map 1, but not sure since the BT refuse to connect at the handshake stage.
I also managed to get the front wheels to screetch a little from a stand still start at a red light with a hard push on the pedal.
Mine does that on occasion. Dismiss the app completely then open it back up.
doesnt work, i have also cleared the data, rebooted the phone and rebooted the car. It finds device, checks pin (1234) and then tries 5 handshakes and fails.
Finally did the rear badges. Gt staying on for now, will see how I feel about it later. Plus it started to rain. Again.
Last monday I had a muffler delete done (with new pipes being 2.5" rather than 2") and I had not done my homework too well and did not know that I would require new tips instantly, therefore I've been driving around with an enormous level of inside the cabin noise (especially low rpm-slow acceleration reverberation as well as 3000+rpm in 2nd/3rd/4th gear).
So today I ordered new tips that I will get welded on to the new Y pipes on both sides on wednesday and also some STP sound deadening materials to sound deaden the whole trunk area + below the rear seats. My understanding is that these two things together should kill the reverberation inside.
We tested how big of an effect the poorly shaped bottom area of the trunk has on the reverberation and it was huge, when things are inside the way it creates the extra noise is crazy compared to when the trunk is completely empty.
But until then, a picture of the beautiful handicraft under the car.
In the long run will make it into a custom system with remote EVC-s and probably some crazy sound when the valves are open!IMG_7658 2.webp
In the long run will make it into a custom system with remote EVC-s and probably some crazy sound when the valves are open!View attachment 45579
Can you do a sound clip when you get the Y-pipes on?
Or, just not put on the front plates. :)
Works around here. But that's because no front plate is not a first offense; cops can tack "no front plate" onto a moving violation, though they seldom do.
