JB4 Question, OBDII Cable?
Spaceme17
So I just purchased a 2020 Stinger GT2. I am obviously interested in the JB4.
In reading about it, is says in the install PDF the following: "The optional OBDII cable unlocks full CANbus control for the most advanced tuning and logging features and is strongly suggested."
What is don't understand is does this come with the JB4 or does it need to be purchased separately? Is that the same thing as the BMS data cable?
Thanks for your help.
OBDII cable is included with the JB4, unrelated to a data cable or blue tooth adapter.
well, did you get it? it's awesome, yes?
So I got everything installed. Took my time to route the wires as cleanly as I could and make things look as factory as possible.
Couldn't connect the the JB4 with Bluetooth on my Note4 phone but my iPhone 5S and iPad had no problem.
Haven't done any testing yet. Just did a quick drive to make sure the car was acting normally.
I also bought the underhood beauty covers. Gives the install a nice clean look.
look forward to your feedback. i added the BMS Pedal Tuner and it's also fantastic. 10% throttle equals flooring it! LOL. This thing just wants to run.
Hey, i have installed the jb4, HKS spark plugs on my 2.0T stinger. the thing is amazing!!! i did not install the OBD11 connection just because however, i get a silly check engine light and after reading the code, it seems that the IAT sensor does not like to play with the unit. has anyone seen this error? even on the V6? when i disconnect the jb4 and plug everything back up as stock, error goes away....
