Maybe there's an issue with your car. My wipers work great, my headlights work great. There are certain conditions for each which depend on the cameras and sensors on your car.Some technologies are nice, but I find the auto wipers and headlights on the Premium to be VERY annoying. I try not to use them if possible, which is even more frustrating. They are definitely not engineered correctly.
This and the auto wipers drive me nuts the most on this car.
The auto high beam picks up many house lights, etc. flicking them down and then back up.
Oh and how do you turn off the auto high beam when high beam assist is active and on low beam mode.
The answer is you can't do it without flashing someone with your high beams.
Then the wipers seem to have a mind of their own. Work fine one minute, then don't wipe enough, turn up the sensitivity, and next thing they are running on high![]()
Hmmm, I tried it last night and well... Yeah. You turn your lights on manually to "ON" and there is no auto high low.Maybe turn the headlights to “on” rather than “auto” to deactivate without flashing?
I had and ‘03 Tacoma, and I just left them on for the life of the vehicle. They’d turn off with the ignition.Hmmm, I tried it last night and well... Yeah. You turn your lights on manually to "ON" and there is no auto high low.
I had always left mine in Auto thinking that it was for auto on/off. Ran the last car for 9 years without moving the lights off of auto.
Thanks, learned something (and you're probably like RTFM)
Auto lights work perfectly fine for me, but I agree, the auto-wiper/speed is so inconsistent.This and the auto wipers drive me nuts the most on this car.
Working as designed. Everyone’s does this.I have a question and thought I should not start a new topic.
When the high beams are on, does your dynamic low beam still work? Going left-right while turning the steering? I noticed that mine doesn't anymore. For example if I am in the middle of a soft bend, the low beam would dynamically move to the interior of the road, as normal. The moment the high beam is activated (automatically) I can see the headlights move to the default centre position. And while the high beams are on the lights don't move anymore.
I find this very annoying and hope there's a problem with mine. My former VW's dynamic xenon lights would behave exactly the same in both low beam and high beam.
I’m not here to explain why.But why? What is the logic of disabling a very good system? We have very curvy roads around here and there are many cases where high beams are far worse than "adapted" low beam. It makes the auto high beam useless..
