just call a PDR repair shop . Cheap and it will be as close to perfect as you could hope for .............my $.02How can I get to the inside of the rear quarter panel close to the trunk trying to remove a dent that the kids made ugh
Does the plunger HAVE to be clean?Hot water and a plunger
or pay someone
preferably not ...........................Does the plunger HAVE to be clean?
............125 - 200 , Cheap !Cheap?![]()
Thanks will look into itjust call a PDR repair shop . Cheap and it will be as close to perfect as you could hope for .............my $.02
How about that picture?Thanks will look into it
they probably can do it with a mobile unit at your convenience ..................google PDR and see the types of repairs they can do and how they do it , its a gamechanger for body damage .Thanks will look into it
These are the images
Definitely take that to a professional, that could be an awkward spot to get to, if even accessible.
Make sure you sufficiently deduct that cost from your children(s) current or future allowance until the cost if fully recovered...
That's quite a guess without seeing the damage.............125 - 200 , Cheap !![]()
PDR can certainly remove that dent , but you are correct , the paint was compromised and that spot will need to be touched up or the panel repainted ...................After seeing the picture, that damage will require paint!
Not sure how a PDR repair will fix that one.
But yes, that would be cheap.[/QU
