itguy61
I installed this and I am smelling the gas/oil smell after shutdown when the engine is warm. It is coming from the catch can. I have checked the hoses, the hose connections and made sure the canister is tight and the gasket is on right.
It seems as if the smell is coming from the fittings that are screwed in to the catch can that the hoses attach to. How many times did you wrap the Teflon tape around the threads? Is this supposed to seal the fittings? Would not having enough tape allow these to leak the fumes here?
Thanks
Thanks
