The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Premium is recommended. But the manual says to run 87 or higher. Haven’t tried 87Picked up a 3.3 rwd today. Dealership is insisting it runs on 87. I'm used to 91 coming from a turbo 4cyl.
If you're using 91, please explain why
Not true. The manual says anything below 87 octane can cause serious damage to the car.It will run on 81 too (if thats even a thing) the difference is how well it will run and the performance of the engine. You should be running 91 or 93, whichever is in your area. The cost difference between that and 87 isn't worth it, a couple bucks a tank at best.
Someone please correct me if I'm wrong but doesn't the lower the octane mean it will combust earlier?
Loved blowing past struggling econoboxes climbing those twisting mountain roads up Big Thompson canyon headed for Estes Park. My new Stinger will get a chance this summer to duplicate that.
Modern engine management systems use knock sensors to identify whether the engine is experiencing detonation and then will retard ignition timing to stop the detonation. Retarding the timing results in a measurable power loss. This is why if an octane of 91 or 93 is recommended, you could still run a lower number like 87 with reduced power output. The system can only compensate so much which is why going very low, say 85, could cause detonation that the system can't adjust out and engine damage could result.
Good to know. Thx for sharing!Yep, I filled my last tank with 87 just to try it out. I noticed the difference in responsiveness and overall thrust. Not putting 87 anymore.
I think we need to avoid confusion. In Europe 98 = 93 in USA98 for me
Man you're lucky. Around me the difference between regular and premium can get up to 60 cents a gallon so you're looking around 9 bucks for a fill-up. I'll definitely try out 87 once I've got a Stinger, then likely end up switching back and forth based on if I'm doing any boring highway road trips or if the weather will be bad that week.The cost difference between that and 87 isn't worth it, a couple bucks a tank at best.
And the Guinea Pig Award goes to....Yep, I filled my last tank with 87 just to try it out. I noticed the difference in responsiveness and overall thrust. Not putting 87 anymore.
What about octane boosters? Any benefit or just a waste?
