Hello guys,
I'm not much of a social media person but I've been told to post up my results and share it to the community, so here are the results of my ever growing stage 1 tune.
This is all on a stock unmodified AWD Kia Stinger GT2, there are no physical performances mods done yet to the car. So far I've been able to achieve 401whp 449tq on a mustang dyno (best baseline on the mustang dyno when on stock tune was 316whp and 336tq) and recently 410whp and 479tq on a dynojet (boost was a little lower on this revision top end but the torque was impressive)
On the 3.91 0-60mph the 60ft was a 1.82
Both of them had a bit of wheel spin for a fraction of a second when the boost ramps in.
I will be getting primaries and Intakes made soon, once I have them I'll see what I can get out of the stinger for when it actually has some performance mods on it.
Let me know what you guys think!!
Thanks,
Chris
edit: Topic title edited by Admin.
- Target boost 17-17.51psi
- LC RPM is set at 2500rpms either at 2 or 4psi (4psi is useless on the oem stock tires)
- No boost drop on shifts
- No throttle closure at all
- Lambda Commanded Target on 93oct is .83
- Engine Load, Turbo Pressure Load, Turbine Speed Limit, COT protection have all been adjusted and or disabled
- WGDC% have been adjusted to hold steady boost all the way to redline and on shifts
- MPG if you cruise nicely I've achieved 30-32mpg on a 2hr trip on pump gas, E45 netted me 24.6mpg on the same trip. Average Mpg combination when beating on the stinger is 23.1mpg on 93ct and 18.7mpg on e45
Thanks,
Chris
