New canned tune option from BTR
falanger
USA
....you go first .......................:whistle::whistle::p
What happens when you do an ECU tune like this and put on piggyback after like the JB4?
All depends on what you do with the jb4 - Terry was just advising someone else - start with map0, log it, and ask him for the next step. Probably move to "add/remove boost by gear" or something for a custom setup.
Alphaspeed Canned Tune ECU Service Kia Stinger 3.3TT / Genesis G70 3.3TT / Genesis G80 3.3TT
Looks like a conservative tune (408 HP, with intake and catback). According to the description it makes the exhaust pop and shoots flames....:cautious:
Yeah 408whp is actually disappointing, especially with intake and exhaust. Kagantuned is making more whp already with absolutely no mods at all, and he expects 440-450whp with only intakes.
Also the fact that they are asking for $1800 for their tune is insane and double what Kagantuned is suggesting. That’s as much as a lap3 and JB4 combined but makes less power than either one.:rolleyes:
The tune is $600 lol
Technically it’s not a canned tune. You do have to remove your ECU and send it to them. You got me all excited it’d be a handheld tuner.
I just looked and it said $600
Yeah that’s only if you send your original ECU in to be cracked and don’t care about losing your warranty. If you have any engine or drivetrain issues Kia will easily be able to see your ECU is modified and most definitely deny any warranty claims.
Most people don’t want that issue and would have to spend $1800 for a cloned ECU & tune.
Why though? Kia can just see the higher toque values in the trans and stability control modules through their OBDII scan if they want to check.
It's on the same calibrations as the stock evu so again they have to be looking for it. Any tuning solution they can find if they really want to look for it.
@DaBears4Lyfe any videos of your car with the Tune. Would like to hear the pops and crackles.
I still have all 4 cats I'm not popping or banging eith them on lol. You want pops and bangs you really need to be catless
Big stage 2 is happening on the 6th. I wanted two weeks to dial in a jb4 map with terry to stack with for everyone.
Stage 2 will be intake, catless exhaust, fmic, e30, meth ... the f*cking works lol. We are going to throw it all at her.
Sweet. Keep us posted.
I'm really concerned about lean that car is @ peak tq. That is dangerously lean, I wouldn't run a NA car that lean @ WOT... You litterally asking for a parts failure.
UPDATE:
I talked to Jesse he assures me that its not really that lean, Though I would argue he should be richer down around 250wtq or 2200 rpm (Assuming there is a delay in the sniffer reading though in my experiance on the rollers the delay is normally 500-750rpm or so.)
That being said I think they should do some better pulls because that dyno graph tells a story that ends in a Built block...
In case you think I don't know what I'm talking about...
Links: Air-Fuel Ratio Meter Tuning- Car Craft Magazine
BTR posted a tune progress update earlier; 469/484 for FBO and E30.....
