Flameangel
2500 Posts Club!
Happens to my Optima now and then but always clears
I had the exact same thing. High beam light was out also. Took it to the dealer and was replaced under warranty. My GT1 is also red. Also same side (passenger).So I checked here because up to now I've had a bit of fogging one one headlight, but it always went away as described, but as of a few days ago, it went crazy, my passenger headlight is completely fogged over and the air has been fairly dry for days, it's not improving.. Anyone know where these vents are that i can try blowing them out?
(these pics are days apart)
Those pics are WHITE, with a little "-" hiding in the middle of all the white. How can you see anything in all that white "fog".(these pics are days apart)
Eeeeee now I have Kia sundial!!!They are typically tubes with filters in them, you can't "blow them out".
Moisture is not getting on the lighting elements, it's just condensing on the inside of the cover due to differences in temperature. It may take a while to clear out but parking so that the headlights are exposed to sunlight may help accelerate the process.
Same here, getting a little worried. It has been 5 days and so far it does not seem to be improving at all...
Any tips? Should I try to access the headlight and maybe use a hair blow dryer? Or is it sealed so I should just take it in to get it checked?
