GT2 AWD Snow chains?
Anden L Schmitt
What snow chains can or should I get with my stinger, I'm going up to Colorado and ima need a set. The owners manual isnt very helpful and I'd love to not f*ck up this beautiful car.
Standard wheels and rims for a GT2. *19'*
In the owners manual it said that not all chains will be compatible even if they say they are, so I'm looking for an actual answer of THIS is what you should get, or THESE are all options you can get that will ALL work.
My 2019 Stinger manual recommends using “Autosock fabric chains” with my RWD 2019 Stinger base. I actually went to Les Schwab Tires (in Portland, Oregon) asking about chains for the Potenza 225 R18 tires that came with my Stinger. They told me that they didn’t stock chains for that size tire and instead recommended Autosocks. I’ve never used Autosocks and am skeptical that they can be as grippy as chains and the dealer at Schwab agreed. Portland, Oregon only rarely gets snow, so I opted for RWD rather than AWD when I purchased my Stinger. The only scenario I see needing chains is if a sudden snow storm unexpectedly dumps a lot of snow quickly while I’m at work(this has only happened once during the past 15 years I’ve lived in Portland). The Autosocks are easier to place on the tires and also less expensive than chains. If not used, Schwab allows returns for full refunds after the winter, so I purchased a pair.
I have used autosock before on my Optima, you'll be surprised how much grip it has. Plus install in seconds:)
