Ulikefishsticks
- Sep 1, 2019
So I got my JB4 a few days ago and I want to install it this weekend. I'm still waiting for spark plugs that are on back order. I will only be running map 1 most likely or just stay in map 0 until I can swap out the plugs.
I went out there a little while ago just to check out how I was going to try to install everything and I was wondering about the OBD2 connection. I am having trouble picturing being able to access the brake boost cover on the firewall inside the engine bay. What have people been doing to make this easier? Should I be removing the ECU? Coat hanger trick? Any tips on this will be appreciated. Thank you!
