Welcome aboard, @Archibald! Thank you for signing up...Might be a firmware update required, but I cannot get my centre display to dim. Tried going under Illumination, Night Mode, Dim Level to max dim. Nothing changed. Anyone else?
No, that only dims the dash display, not the centre panel. Did get a firmware update from the Dealer today, so I'll let you know when it gets dark out.Does it dim when you use the brightness buttons to the left of your steering wheel (where the buttons for LKA/trunk open/fuel cap open/etc. are)?
Thanks!Welcome aboard, @Archibald! Thank you for signing up...
Mine also dims the centre display.No, that only dims the dash display, not the centre panel. Did get a firmware update from the Dealer today, so I'll let you know when it gets dark out.
You may want to check the ambient light sensor... try putting the headlight switch to auto and see if works.Just had the firmware upgrade at the dealership. Unfortunately, no change :-(
