Aftermarket iDataLink Remote Start Install
ecko04
After reading up on the factory (OEM) remote start I decided I did not want to restart upon entry and the aftermarket CAN bus module appeared to be a fairly over complicated install for what it provides. Therefore, I went to, what I consider, to be the next best option and will be installing the iDatalink HC3452A, which includes the CMHCXA0 (control module), ADS-AHR-HCA (analog harnesses), AN2400A3 (long range antenna), and 2X TR3450AF (two 2-way 5 button mile range remotes).
This is *NOT* intended to be a DIY. I cannot recommend a novice attempt this install. If anything, it should serve as a reason why you should seek professional installation.
Caveats:
  • I am a MECP Master Certified Autotech
  • I have a background in 12v electronics
  • You need a programmer, and a Windows PC or Mac with Bootcamp, to program the module.*
* There are also Android and iOS programmers, but they're more expensive than the traditional USB programmer.
Why this unit and not say a Viper (DEI) or Python (also DEI)?
This is personal preference, but I do not believe that Directed Electronics has evolved in any appreciable way over the last 5-8 years. I used to swear by their products (Viper, Python, etc.) but having used Compustar, almost exclusively, in manual transmission cars due to the ease of install, module wiring layout, and takeover process, I became a convert. In addition, DEI never evolved to include a transponder inside the control module therefore alleviating the need for additional modules and wiring. And maybe DEI has evolved, but I haven't bothered to look and my circle of installers and engineers haven't mentioned them so I would assume they haven't.
So why not Compustar?
You cannot go wrong with the iDataLink or Compustar, but the simple fact is that both systems are very similar that you'd think there was a collaboration -- and to think of it I believe there was in terms of transponder technology. Where the the Compustar comes out on top is the ability to add additional modules. For example, you can add the alarm module to the Compustar and have a full fledged active alarm with siren, tilt switch, and shock sensor. The iDataLink can also add an alarm, but it's more basic and doesn't have all the functionality of the Compustar offering.
What the iDataLink does have is two 2-way remotes that come with the system. If you price out a two-way remote, which is one that not only sends a signal to the car but can also let you know it has been received, you will find that these remotes typically are $100/each, and they're giving you two of them.
Even still, I don't plan on using those remotes at all since I do not plan to carry more than 1 remote. The iDataLink allows you to use the factory keyfob to start the car by pressing the lock button three times successively, granted at a greatly reduced range compared to the 1 mile 2 way remotes included.
Additionally, the real benefit is with the takeover process where you simply enter the vehicle as normal, close the door, put your foot on the brake and remove your foot, and you're ready to go.
Of course there are additional things you can do such as increase the runtime, enable a turbo timer, passive locking, hatch release, etc.
Lastly, ease of install. There are 18 wires total that need to be connected. That may sound like a lot, but that's nothing when you're not using about 40 of them, which means the install should be relatively clean.
Ok, so what's the price: $250
Package was delivered today. Comes in a nice tidy low profile box.
Opening the primary box reveals three boxes.
1) Analog harness
2) Remotes
3) Remote Start Module
Module
Everything connected, which can be a bit intimidating, but you do not use all of them.
Now it’s time to do bench prep. This step is crucial. It means we are removing wires and harnesses that are not included in this install.
Here is the regular primary harness. The primary harness consists of heavy gauge wiring for 12v, ignition, starter, etc.
Here’s our paired down main harness.
I simply tapped the second 12v wire to the first, and the second ignition as well as the wire wire are not used for this install.
Next up is this harness
We pair it down for this install, which is using two of the wires (green/white and green/black)
Luckily, we do not use this harness at all.
Here’s our next harness
For this install, we’re using a few wires to handle the encrypted transponder encoding as well as the takeover procedure.
Finally, we have the last harness that interfaces with the anti-theft system.
I do not have a before picture, but we are using only 4 wires.
Here’s the end result. These are all the wires that I’ll connect in the morning and wrap this install up. There are 16 total.
Got around to completing the install today.
Here's out takeover wire, which is located on the rear of the dash fuse box.
Positive trigger parking light wire at the light switch.
Starter wire in the passenger kick panel(Brown/Orange)
CANbus data high and low located on the back of the dash fuse box
Push-to-Start wires at the PTS button
12v located at the dash fuse box
Immobilizer data in the driver's kickpanel
Accessory (white) and Ignition (red) at the dash fuse box
Overview
I went some what in your direction..
I instead went with a compustar dc3..
Which is the same basic install as the one you are going with..
PS Viper does have an all in one.. Its called a ds4. But they do not currently have firmware out for the stinger.
So basically DEI still hasn’t evolved. We’re entering the 3rd model year for the vehicle and DEI still has no firmware and would prefer installers wrap a key with a 556U.
At least they have firmware for the Telluride.
I had my dealership install a starter from idatalink in my Forte. Having them do it had it covered with the 5 year car warranty. After two years the starter has been flawless.
What are your thoughts on this guys? I was considering compustar ... never heard of idatalink. Great thread here.
I'd never heard of them before until getting my remote installed. They actually have a wide range of products and are pretty highly regarded. Especially in the KDM market.
Caveats:
Ecko-any chance you'd be able to program one for someone else? I'd like to do a RS system and this also seems like a good option.
iDataLink is simply a brand made by Automotive Data Solutions. They also include Flashlogic and Blade. Blade is used almost exclusively with Compustar, which is also a brand made by Firstech. In fact, Compustar’s remote start modules have a slot that accepts Blade transponders. Also, Automotive Data Solutions and Compustar utilize the exact same interchangeable t-harnesses making installation on about 70% of vehicles a breeze.
The CAN bus module works fine, and for those who have it installed correctly, and enjoy it.
I think most folks would use it for the remote start function and it’s cheaper than the flawed OEM solution. The install isn’t prohibitively complex but does take time and should only be done by a professional (i.e., someone with insurance if the wrong wire is connected to the wrong component). I wouldn’t recommend a novice to DIY it.
I could, but it’s not something I’d want to do. There’s programming that needs to be done once the unit has been installed as well.
Let’s just assume something goes wrong during the flash, but I didn’t recognize it at the time and sent it to you.
You then go through your entire install and make it to the end, but the vehicle-side programming fails and you don’t know what’s going on. Let’s assume your install was perfect, and you’d think the transponder module was perfect too, you’ll end up spending a bunch of unnecessary tracking down a problem. Then you’d have to send it back to me, I’d have to reprogram it, send it back to you, etc. How many days of downtime are we looking at? Or you’d have to uninstall, and reinstall once you get it back.
Maybe once I wrap things up on my side I can do a little pay-it-forward on a programming cable. Each person use it and send it to the next person type thing.
OP updated
Could you point us in the direction of the programmer or a how to? This install looks like no big deal. I have been doing all kinds of electronics for a while so I'm not scared of doing it. I would however like to do it right. This is honestly the only thing i NEED in my vehicle right now for the winter. Help a brother out?
iDatalink ADS-USB
You’ll need a verified installer account to access the firmware to use the cable to flash the module.
The install is more involved than most others.
