Are you using a wrap-around strap like you'd use for a spin-on metal filter?I find the opening very small to fit an appropriate ratchet tool to undo the filter housing.
conventional socket at the bottom.
Has anyone tried removing the oil filter from the round access panel underneath? I cannot seem to get any tools in there because there is a motor beneath the filter housing.
Oil change is included in our fixed price servicing. Filter housing is very close to power steering motor so not a lot of room. Much easier to drop the under body panel.No issues here but you're in AUS (would be handy to put that in your profile btw) and I've seen this come up once before.
Seems odd that we didn't hear of it a lot earlier, does hardly anyone in AUS change their own oil?
Every manufacturer has their quirks. My Ford Explorer if you weren’t paying attention would drip near/on one of the cats. My moustang the frame.Thankyou Shannon! This is exactly what i mean, that motor is covering 3/4 of access passage. I'm also concerned about oil dripping from filter all over the EPS motor.
Did Kia intentionally make changing oil and filter so difficult on these?
I'm going to speculate that this is a RHD market concern. The oil filter is going to be in the same place, but the steering components are not.Bizarre! That power steering motor is not in that same location on mine.
Are we talking about the same 3.3 V6 engine?
