Team Tonka
- Jun 13, 2019
Has anyone running 93oct increased the boost values in the lower RPM ranges - if so, what would you recommend for MAP 2 on 93 Octane for a starting point? I'm AWD.
Below are the boost values for Map 2.
psi_curve[0] = 4.0 '1500
psi_curve[1] = 4.0 '2000
psi_curve[2] = 4.0 '2500
psi_curve[3] = 4.5 '3000
psi_curve[4] = 5.0 '3500
psi_curve[5] = 5.0 '4000
psi_curve[6] = 5.0 '4500
psi_curve[7] = 4.5 '5000
psi_curve[8] = 4.0 '5500
psi_curve[9] = 4.0 '6000
psi_curve[10] = 3.5 '6500
psi_curve[11] = 3.5 '7000
