Yes, I paid more for the HKS plugs than I otherwise would for Denso plugs. You know what else I’m doing? NOT spending my time hunting down spark plug issues.
It has been erroneously stated over and over again that colder plugs will foul quicker. This may have been the case in 1990 but it’s simply not true in 2019. In fact, it’s preferred to have a plug foul due to it being colder than the alternative when it’s hotter, which is severe engine damage.
There has been absolutely no evidence to suggest that colder plugs will expedite the need to replace plugs. In fact, quite the opposite seems to be the case, where stock plugs are the ones fouling and in need of replacement sooner than the interval would suggest and clearly some of the Denso plugs.
While someone may have spent $150 on HKS plugs, point me to the thread where the certain has cracked, plug has failed or coil has gone bad for anyone running HKS plugs. The sample size is smaller for sure but the failure rate at this point is nil.
I don’t know about you but if it cost $150 to not swap Densos every other oil change — downtime and labor add up — sign me up for that any day of the week. I’d prefer to not have to hunt down which plug decided to opt out of functioning.
What anyone chooses to run is their decision; I was simply adding to the discussion that some of us are not using Denso plugs and we’re hard pressed to find links to failure with those. Maybe it’s the Canadian fuel, maybe it’s the plug or maybe a combination.
No need to be defensive. I’m not criticizing you or saying you made a bad choice. I’m simply starting the facts.
You and probably 99% of the 1000s of Denso users are not hunting down spark plug issues either. The couple of examples stated here doesn’t represent the rest of the users that are happy and having no problems with their plugs.
And not sure where you’re getting your info, but it’s documented and proven that colder plugs do not get as hot, and in turn do not burn off as much carbon deposits. Carbon deposit buildup usually causes detonation which is dangerous in itself and can cause more damage than just blown plugs.
I do partially agree that it’s generally better to have a fouled plug than a extremely hot plug that may malfunction. But that would only happen if your usually running significantly more boost than map2/3 and making more than 100hp over stock power levels. If that was the case than using 2step colder plugs would be fitting, however most JB4 users don’t use map5, 7 or 8 so that only applies to a very small percentage of users.
Again your assumptions are incorrect and it’s well known that running higher boost will wear down electrodes faster and in turn need plugs to be replaced more often. Higher performance plugs are also known for quicker replacement because they are generally causing more wear & tear due to running more power. Simple explanation here.
How Often Should Spark Plugs Be Replaced? | YourMechanic Advice
And stock plugs have had issues simply because of Kia’s poor gapping parameters. Almost everyone that had issues with stock plugs, including myself, found that it was due to unusually large & inconsistent gaps, some as a bad as .038”
Again, not arguing that HKS’s aren’t good plugs but I personally know someone that just got rid of his M45ILs because he was having serious misfires running the JB4. Even if there were ~1/100 JB4 HKS users with issues, that’s a much higher percentage of failure rate than the ~3/1000 of Densos with problems...
I doubt anybody is replacing Densos around 10k miles unless user error, bad gas or too much boost for step1 colder plugs. Also, Im pretty sure most people only running map1-3 would rather spend $50 to get 20k-30k miles out of Densos with a next to nothing chance of issues, than to spend $150 for HKSs that have a higher failure rate %, increased chances of fouling, and likely have to change them in less time.
I agree that whatever anyone wants to run is there decision, and everyone wants to defend their own choice. However your input, even if unintentional, gave the impression Denso users made a mistake with their choice.
Bottom line, both plugs are great and the facts show that issues are extremely limited and likely caused by other circumstances than just one plug being vastly superior to the other. Just saying, be happy with your choice and try not to make others feel that they made the wrong one when all the facts say otherwise.
