blind spot
agk
has anyone experienced the blind spot mirrors shutting down while driving?
What? Elaborate please? Do you mean the Blind spot indicator not working?
If so, 1st.. check you dash settings to make sure it’s enabled. 2nd, there is a button that will light up when enabled near the gas cover release.
Make sure it is pushed/lit.
If that isn’t what you mean, we need more info.
blind spot indicator not working on dash nor mirrors. It works when driving , then a warning appears on dash saying that the monitor has been disabled and a yellow triangle appears on dash. When car is restarted the blind spot monitor works.
It could indicate a weak battery or a problem with the alternator not charging the battery.
Dealer has looked at car twice and can't find what causes problem.
That sounds like whatever radar emitter or receiver is used to create the warning is having issues so they're turning the service off.
