Hi guys, I'm getting what looks/sounds like knock when running Map 2 (logs and snapshot attached). I have a late 2018 Stinger GT2, AWD with brand new (less than 200 miles) Denso plugs from the JB4 site, gapped between .022 and .023. Other than the Denso plugs and the JB4, the car is 100% stock. Also, I'm on 93 octane from a local Shell station which came recommended from a fellow tuner (500WHP BMW)
Here's some other important info. Map 1 runs excellent with a very noticeable power increase, near perfect timing curves, and steady boost through the whole RPM range from 1st gear all the way through 3rd. The JB4 was only installed yesterday so I only have about an hour of drive time on Map 1. I tried Map 2 today since the Map 1 logs were good (confirmed through email with Burger Motorsports).
Just after going WOT (wide open throttle), I hear what sounds like rocks being shaken in a can for about a half second, then nothing except the engine revving until it shifts from 1st to 2nd, then I hear the rocks in a can sound again for another half second right when 2nd gear engages, then no more rocks until shifting into 3rd. Basically, I only hear that sound for the first half second or so of each gear shift at WOT. I don't hear the sound at all during normal driving.
I took a look at the logs and my throttle dips, even though I have the pedal to the floor. At the same time, my timing and boost make consecutive drops all the way through the RPM curve until I shift into 2nd. After that, the logs look pretty normal. From everything I've read, those consecutive drops are to stop knock that's been detected.
Anyone else run into this issue with a stock Stinger on 93 octane? I'm emailing back and for with Burger Motorsports about it, but I figured I'd open this up to the community too.
I expected to run into some issues, but definitely not knock on day 2.
