Dom
Could anyone give me a guide to removing the rear diffuser -the glossy black plastic piece at the bottom back which surrounds the exhaust tips?
Cheers!
Cheers!
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I'll be doing it in the next day or so.....let you know how it goes.Could anyone give me a guide to removing the rear diffuser -the glossy black plastic piece at the bottom back which surrounds the exhaust tips?
Cheers!
Great. Thanks.I'll be doing it in the next day or so.....let you know who it goes.
Me. To replace with a carbon fibre OEM one.What for?
I have a diesel Stinger. It comes with only two exhaust tips on the right. I’m going to change the diffuser and add two tips to the left.What for?
I can't see any rivets - only pressure clips and screws.Drill out the rivets on the bottom corners, push/pull out the pressure clips, remove screws as you encounter them. So on and so forth.
Me too.I can't see any rivets - only pressure clips and screws.
It was under the black trim near the wheel well sandwiching the rear quarter panel and the black trim (90 degree visible only from under). One on each side (at least on my 18). Maybe only on 18’s. I didn’t get why they had it. It was a pita.Me too.
Is it a metal rivet? Did you replace it with something else?It was under the black trim near the wheel well sandwiching the rear quarter panel and the black trim (90 degree visible only from under). One on each side (at least on my 18). Maybe only on 18’s. I didn’t get why they had it. It was a pita.
Metal. Nope. I think it was their attempt to appease a regulator that there was no way the black trim could come off. (Like every screw/pressure clip would fail).Is it a metal rivet? Did you replace it with something else?
So did you just leave it blank?Metal. Nope. I think it was their attempt to appease a regulator that there was no way the black trim could come off. (Like every screw/pressure clip would fail).
Yep. I’ll try to get a pic later today if the spot.So did you just leave it blank?
That would be great. I'm trying to find time over the next few days to tackle this.Yep. I’ll try to get a pic later today if the spot.
the GT OEM Difusser has 2 tips on each side ( attached )I have a diesel Stinger. It comes with only two exhaust tips on the right. I’m going to change the diffuser and add two tips to the left.
Well, how did it go? Got any tips for me???I'll be doing it in the next day or so.....let you know how it goes.
